Ansys Learning Forum Forums Discuss Simulation General Mechanical Triggered Internal Heat generation Reply To: Triggered Internal Heat generation
anastassiosm
Hello Erik Thanks for your guidance I was able to generate the array for Q=f(exp(time)) using the function editor in ANSYS classical and import it in WB. It worked as planned! I was wondering if there's a way to use an IF statement to call this Q=f(exp(time)). As mentioned I want it to kick in at a certain temp. Can I do something like this: IF TEMP=>500K THEN [Q=f(exp(time)) array] ELSE hgen=0.
