Ansys Learning Forum Forums Discuss Simulation Fluids heat flux at interface of porous media and wall in LTNE model Reply To: heat flux at interface of porous media and wall in LTNE model
ss_stardust
Hi Thanks for reply.
This doesn't seem to work. Can you please explain what equations are solved at interfaces as in case of porous media, continuity of velocity, shear stress and heat flux is required. There are a number of models available in literature to have heat flux conservation. Which model does fluent follow? To make my question more clear, please see the attached picture which considers two models. Can you please mention what model is implemented in fluent?
Thanks in advance.
