Ansys Learning Forum Forums Discuss Simulation Fluids Regarding pre filling a geometry before multiphase vof simulation Reply To: Regarding pre filling a geometry before multiphase vof simulation
Sumit_Kumar
As of now, the inlet dimensions are 0.6mm*0.04mm, the particle size is 0.1 um. The particle I am currrently using as a test is anthracite and on water as a stationary fluid. The velocity assigned to the particles is 1e-5m/s.
These parameters are fine, but it would atleast show if the particles are moving by the virtue of their velocity itself. Just to clarify if I am wrong
This is the velocity I am assigning. I hope this only shows the velocity of the particle. The boundary conditions for the fluid have been set as pressure inlet and pressure outlet and the gauge pressures are initialised as 0 so as to maintain the stationary fluid thing going on.
