Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Regarding pre filling a geometry before multiphase vof simulation › Reply To: Regarding pre filling a geometry before multiphase vof simulation
October 31, 2021 at 11:22 am
See thats just it. The time step size is not changing the result as if it did, I would have seen atleast an infinitesimal movement. But the flow is reversed. I even tried to modify the boundary conditions for the fluid making a pressure inlet and a pressure outlet and setting the gauge pressures to 0 for the initialisation before performing DPM. But this does not change anything.
Till now, I do not understand what exactly went wrong with the physics, as it seems pretty accurate in my eyes
