Ansys Learning Forum Forums Discuss Simulation Photonics Changing X- and Y-axis range in the data visualizer Reply To: Changing X- and Y-axis range in the data visualizer
Guilin Sun
Sorry, Power is not "defined", it is an input parameter. If you want, you could do that way by calculating the power from the source amplitude and area. You can use "model" to pass parameters.
