Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Simulation setup for particle between two media. › Reply To: Simulation setup for particle between two media.
July 28, 2021 at 1:57 pm
Hello. I would like to obtain the widefield image (intensity as a function of x and y spatial position) that would be observed using a high numerical-aperture microscope objective (at a single wavelength, e.g. lambda = 500nm, but ideally across the whole visible range). I believe this could be obtained using a planar monitor behind the source collecting the far-field back-scattering (i.e reflected) light. Is that correct? Experimentally we obtain microscope images.
