Ansys Learning Forum Forums Installation and Licensing Ansys Products Issues with FLUENT application Reply To: Issues with FLUENT application
When you open the Fluent launcher set the Parallel Settings "Select IP Interface" to 127.0.0.1 You may also need to set the MPI type to msmpi but try the fixed IP first.
