Ansys Learning Forum Forums Discuss Simulation Fluids How to give viscosity and surface tension under material properties for a solid melting problem? Reply To: How to give viscosity and surface tension under material properties for a solid melting problem?
Dubey92
Thanks for your suggestion. I think this was causing some error.
