Ansys Learning Forum Forums Discuss Simulation General Mechanical Showing failure of elements in block structure under compression Reply To: Showing failure of elements in block structure under compression
peteroznewman
I suggest you run this model in Explicit Dynamics where you will see the failure. Erosion will remove elements during the solution based on a strain criterion (default) or on a material failure criterion if you have that in your material and you change the Erosion setting to On Material Failure.
