Ansys Learning Forum Forums Discuss Simulation Fluids What DPM boundary condition to use to let a particle pass through a wall? Reply To: What DPM boundary condition to use to let a particle pass through a wall?
pmeghana
Yes, i have walls named like that.
the flow doesn't seem to have been affected but, what do you mean when you say, is set up correctly? What would be the possible thing i would set up wrong if this is the case? The default dpm boundary condition i get for these walls is reflect.
