Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unable to converge for a solution › Reply To: Unable to converge for a solution
July 26, 2021 at 8:22 am
Emperor
you can try to join your model by creating an archive from Workbench, it will be easier for us
From your last step, I see that your force wants to converge to the criterion, so you can try to add iterations, to do this insert a command object in static-structural branch, then add the command NEQUIT,100 .
Have you checked the quality of the mesh?
Finally what error message does the solver output show?
