Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Can’t find static structural under the analysis systems in Workbench Reply To: Can’t find static structural under the analysis systems in Workbench
George Karnos
The settings should stick and not reset when starting the program again.
This sounds like a scaling problem with 4K monitor, which is not supported.
Can you lower the screen resolution also?
