Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Why can I not open Fluent (with Fluent Meshing) from ANSYS Workbench? › Reply To: Why can I not open Fluent (with Fluent Meshing) from ANSYS Workbench?
July 22, 2021 at 11:27 am
Rajas
Thank you for a prompt response Rob
I tried again to launch "Fluent (with Fluent Meshing)" and "Fluent" component system in Workbench by following your steps. I had 0 apps running in the background, 0 GPU, and 1 CPU set in parallel. Unfortunately, I experienced the same error in both cases.
I am able to launch Fluent in standalone mode by launching fluent.exe from the ANSYS folder, but I need to use Fluent meshing to use "Fault-Tolerant Meshing" workflow which is not shown in the standalone system. I am required to launch the "Fluent (with Fluent meshing)" component for that. Hence, I'm sorry but that still does not answer my question.
Could you please help me with launching "Fluent (with Fluent meshing)"? Thanks.
