Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Element Alive and Kill Commands with 2D Shell Models › Reply To: Element Alive and Kill Commands with 2D Shell Models
July 22, 2021 at 2:40 pm
Govindan Nagappan
@warrensu
Check the element documentation to see if it support element birth and death.
Example: 2D plane element Plane 183 supports element birth and death and it is listed in documentation here:
From help:
Plane elements are 2D - used in plane stress, plane strain, axisymmetric etc
Shell elements are 3D. See which elements you are using and check the doc for the specific element. Shell181 does support element birth and death.
If it doesn't work on your model, can you show the feedback from the solution information and explain how you defined the Ekill/Ealive. Please insert images to explain. Do not attach files/images
From help:
