Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reverse flow in turbulent simulation › Reply To: Reverse flow in turbulent simulation
July 21, 2021 at 7:44 pm
Hi Karthik
Thanks for your response. I am interested in estimating the wall shear stress on the impingement plate. Though it is 0.20 m long, I am interested in the first 0.02 m (20 mm) since that is the actual size of the plate surface. The reverse flow message appears for pressure outlet ( the top one from the image).
I used k and epsilon for velocity inlet boundary conditions and atmospheric conditions for pressure outlet. The interior and wall are default in Fluent. The k and epsilon values were calculated using equations given in Fluent manual.
Veeramani
Veeramani
