Ansys Learning Forum Forums Discuss Simulation 3D Design How to execute SpaceClaim script within ACT? Reply To: How to execute SpaceClaim script within ACT?
Rajesh Meena
Hello
The SpaceClaim scripting function can not be used in ACT app without importing the spaceclaim libraries.
I would recommend you to first of all use ACT console in SpaceClaim for developing/Testing the code. Please refer to the help manual to check the parent libraries to be imported for a function (C:\Program Files\ANSYS Inc\v211\scdm\SpaceClaim.Api.V19).
For example, to use Direction.Create(0,0,1) you can simply search for this function in the help manual to find that you would need SpaceClaim.Api.V19.Geometry to be imported.
SpaceClaim.Api.V19.Geometry as geometry
geometry.Direction.Create(0,0,1) #Create a direction object
Similarly, List is nothing but a .Net array of type System.Collections.Generic.List.
Hope it helps.
Thanks Rajesh
