Ansys Learning Forum Forums Discuss Simulation Photonics Cannot open “Edit object” window for simulation objects with Script tabs in Lumerical FDTD Reply To: Cannot open “Edit object” window for simulation objects with Script tabs in Lumerical FDTD
williamfraser3
Thank you for your reply.
Where can I find the ini file that I should try deleting? The link you provided points to another link with the location of the file but it when I follow it I am met with this message:
I will have to contact my system admin about the other possible solutions so I will try this first to see if it works.
Thanks again!
