Ansys Learning Forum Forums Discuss Simulation 3D Design Error in importing IGS file to DesignModeler ANSYS Reply To: Error in importing IGS file to DesignModeler ANSYS
mrife
the geometry is readable: the DM tree shows many solid bodies. Select the "1015 Parts, 1015 Bodies" object and check to see if the volume and/or area can be calculated. The geometry may be able to be pushed to meshing, just not manipulated with DM. You can try the different Import options to see if any of the tool choices result in a 'better' import.
That looks like a city - being zoomed into 1 meter resolution is a little to close would be my guess. Try a right-click zoom-to-fit.
DM has a 1 km^3 limit; +/- 500 m box to model in. If that really is a city and its larger than 1 km try Units -> Large Model Support; On. Then do the import.
Mike
