Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to change a SOLID187 into a SOLID185? › Reply To: How to change a SOLID187 into a SOLID185?
July 23, 2021 at 8:05 am
you have to add the extract to each solid in the geometry tree. If you want to use the keyopt on the same element, you must also put matid and not _sid (as far as I know) i.e. :
Et,matid,solid185
keyopt,matid,2,3 ! Simplified enhanced strain formulation
You can then check in the output of the solver that the solid185 has been used with the right keyopt, just do a Ctrl+F and search for "solid185".
