Just to add to comments. The Workbench session can't be saved in an earlier version. However, some of the solver files may be exported and read into an older version: it's not recommended and you will need to check all the settings but it may be possible. Check what export options you have in the solver and see how you get on.
Doing it again will be safer, probably easier and good practice with the software.
