Ansys Learning Forum Forums Discuss Simulation Fluids Can binary diffusion coefficients be somehow defined as a function of two parameters? Reply To: Can binary diffusion coefficients be somehow defined as a function of two parameters?
Surya Deb
If I understand correctly, the electron gas pressure will be a function of temperature as well . You might also want to check the Kinetic Theory approach for the diffusivity.
Check literature to see if you find such polynomial correlations with temperature.
Regards SD
