Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Just monitor. In CFD we monitor residuals, monitors and fluxes. Once the computer says the model is done we also manually check the result: that is to check that the result is "correct" as the other checks are that the solver has done it's job, not that the boundary conditions etc are sensible.
