Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Jason Sum
Nearly 500 iterations
