Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Jason Sum
Got it Rob! Now I am refining the mesh, I found some elements having extraordinary skewness (shown in red), what should I do to specifically resolve them? Thanks!
