Ansys Learning Forum Forums Discuss Simulation Electronics MSMD battery model Reply To: MSMD battery model
ayodeji.adeniran
The Qref is the capacity of the battery used for the experiment from which the NGTK parameters were extracted. If you are using the default FLuent Parameter then just leave it as the default which i believe is like 32.77AH.
