Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › procedure for fatigue analysis of a shaft using a new material other than structural steel › Reply To: procedure for fatigue analysis of a shaft using a new material other than structural steel
February 8, 2021 at 4:27 pm
Aniket
Go to engineering data, by double-clicking on it.nTurn off Filter Engineering data in the upper left cornernin the toolbox under Life, you will find tools for SN curvendrag the required tool on the required material.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
