February 3, 2021 at 1:27 pm
Karthik Remella
Administrator
Hello,nI can provide some information about estimating these times. nYou could use this command but the below will give you more accurate results.n/parallel/timer/usagenThe above command includes only the solver time and to print Linear solver stats etc.. It doesn't include time spent in collecting, and reporting residuals, time spent in calculating and reporting monitors like (force, surface and volume). For measuring wall-clock time the below command should be used.n (benchmark '(iterate 200))nPlease see if these work. nHere is what I'd rely on. Please see the following links below from the User's guide.nI hope this helps.nThank you.nKarthikn
