November 13, 2025 at 4:10 pm
javat33489
SubscriberThe Pretension Bolt Isn't Making Contact
Hello everyone. I'm simulating the tightening of two dies with teeth.
I'm using a Pretension Bolt. But when the bolt tightens, the die doesn't make contact and flies off into space.
I've tried everything:
increased the number of steps
adjusted the contact with every possible setting
added springs
rounded the teeth
made the dies touch with the teeth.
Nothing helps.
Please give me some advice.
Thank you. -
November 13, 2025 at 10:50 pm
Ankush Choudhary
Ansys EmployeeHave you tried adding weak springs? This will stabilize the model. First try using the bonded contact between two and see how it behaves.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
1488
1363
1195
