Ansys Learning Forum Forums Discuss Simulation 3D Design Challenges in BCC Structures: Strut Intersection Issues Reply To: Challenges in BCC Structures: Strut Intersection Issues
Rahul Kumbhar
Hi Giuseppe,
I think in such situation, you might need one more parameter that is center to center distance betweenn cells. This should be first parameter one should change. Then change the other parameters in order. While it is lot of efforts to create C-to-C distance parameters for all cells, it will be easier if you are using pattern tool.
