January 16, 2019 at 12:25 am
SaiKiran
SubscriberHi,
Right now, i am solving the problem in ansys Fluent.
I want to introduce swirl velocity at the inlet, since i am working on 2D model. I have inlet velocity of 7.437m/s and swirl angle 45 degrees caused by Fins. The radial velocity in this case is assumed to be zero.
I need help in solving the Swirl/ tangential and axial velocity components.
Thanks & Regards
Sai Kiran Nunna
January 16, 2019 at 1:43 am
January 17, 2019 at 9:14 am
seeta gunti
Ansys EmployeeWe have options to define swirl velocity under velocity boundary conditions.
Under co-ordinate system, you can choose cylindrical swirl and provide swirl boundary conditions.
seeta
October 4, 2023 at 11:58 am
anxo.ramos.fontelo
SubscriberÂ
Hi, I am trying to simulate an actuator disk to show results as a drone propeller. Firstly I calculate the pressure drop of the actual drone propeller (MRF) between upper and lower surface (see image) and now I am trying to set this pressure drop onto the disk actuator simulation by setting a plain surface with the diameter of the propeller as a fan. My main problem is that if I only set the pressure drop as a constant I do not get accurate results, so I would like to know if I should also set the swirl – velocity specification on the fan dialog box and if so, how can I get those parameters from the actual propeller simulation? Since I am a bit lost right now.
- The topic ‘Calculation of Swirl Velocity’ is closed to new replies.
- affinity not set
4167
1487
1363
1194
