November 26, 2018 at 4:54 pm
saipremsuhastavva
SubscriberHi,Â
I'm using the ANSYS 19.2 Version. I have developed the geometry in Ansys. I'm trying to perform the 2D Analysis . I have selected the analysis mode as 2D before initiating the project . After performing the mesh when I rotate the component I can see some extrusion body. It doesnt look like the 2D object. But I'm sure that I kept the thickness as 0 only.
November 26, 2018 at 5:00 pm
peteroznewman
SubscriberHi,
On the main menu: View, uncheck Thick Shells and Beams and you will get a zero thickness view of the mesh.
This is just a display setting and will not affect the FLUENT model.
Peter -
November 27, 2018 at 2:43 am
Keyur Kanade
Ansys EmployeeYes, this is just display settings.Â
As question is answered, please mark this as 'Is Solution' so that it will help others on forum.Â
- The topic ‘In 2D Fluent Analysis’ is closed to new replies.
1487
1363
1194
