November 2, 2018 at 2:57 pm
bektass
SubscriberHi everyone,
? m working on two-phase unsteady particle tracking with 3D geometry. One phase is water-liquid(continuous phase) and other nitrogen. the volume fraction of nitrogen is sufficiently low in terms of water-liquid. Actually, ? wanna track one or two nitrogen particles in the flowing water-liquid and ?'m using the eulerian method with eulerian parameter which is dense discrete phase model as multiphase model, injection type is group in the fluid domain.
Is it logical or not? If your answer is no, can you give me advise for my model. Because ?' am not sure about using dense discrete phase model which is the only granular type particle or not.
Thanks for your time.
November 2, 2018 at 4:16 pm
Forum ModeratorIf you're looking at a low particle loading the DPM model is the best one to use. Read up on it in the Help to understand what the benefits & limitations are.Â
November 9, 2018 at 1:07 pm
bektass
SubscriberI will investigate it more. Thank you for your time.Â
- The topic ‘Two Phase Unsteady Flow Particle Tracking’ is closed to new replies.
- affinity not set
4167
1487
1363
1194
