problem adding acoustic absorption surface
    • ORHUN OKCU
      Hello, I have been trying to do acoustic modal analysis of the room with absorption surface at the bottom of the room.  I could not add acoustic absorption surface into my modal. I created box and the imprint surface at the bottom by extrusion. (I followed the book named Acoustic Analyses Using MATLAB and ANSYS). When I select this surface, the question mark is appear. How can I solve this problem. By the way, I am using student lisence. Thank you in advance.
    • ErKo
      Hi
      That should work only on a single non shared face belonging to an acoustic region made of a 3D part/body.
      Also one needs to activate a damped solver since this adds damping – done under analysis settings.
      One can see this error when trying to solve your system as it is – it will prompt the user to use the damped solver.
      Thank you
    • ORHUN OKCU
      First of all, thank you for response. I turned the damping on but I have still question mark. How should I add the surface to my body? I have created surface from the sketch by extrusion. Then I select the operation as a imprint faces.
    • ErKo
      I meant face  – so it can be scoped to a face belonging to a part/body. So for sure there is something going on with the geometry – can you show it please and the list of all parts involved (also it can not be an interior face).
      So do a simple example - do a cube - and scope the absorption surface to one side/face - that should work.
      Erik
    • ORHUN OKCU
      I scoped by the using both geometry selection and the named selection. I selected from the outside as well. But question mark still remains.
    • ErKo
      Try to start from a new project – create a BOX in designmodeler. Then apply it to one of the sides/faces of the cube and that should work (as shown below) – try that.
    • ORHUN OKCU
      Sorry, I have done what you said. I think I am doing something wrong. What I have done is create the box. Then I assigned the air as material to acoustic region. Then I scope one face of the cube for absorption surface. I have still question mark. This is my screen.
    • ORHUN OKCU
      How can I lift the question mark from the acoustic region without material assignment? Sorry for bothering. I am real beginner.
    • ErKo
      No worries – can you show the details of your solid body (want to see what material it has), and show me the analysis settings just like I showed.
      Also take away that material assignment and use directly as shown below:
    • ORHUN OKCU
    • ORHUN OKCU
      Thank you so much. Have a nice day
    • ErKo
      Not in Designmodeler – in modal acoustics/mechanical like I showed in my last image – make sure you select air like shown in my last image - if you have that (Air) and it does not work press the button indicated below to show the error message – all the best
      Erik
    • ORHUN OKCU
      It worked. Thank you very much.
    • ErKo
      That is great - can you share and say what you changed to get it to work please incase someone else has the same issue.
      Please share below
    • ORHUN OKCU
      I have assigned the air for the solid body from the body detail page. The question mark next to absorption surface turned to check. For those who encounter a problem about adding absorption surface make sure that your solid body material is air.
    • ErKo
      Thank you - yes, we need to have acoustic properties/material for acoustic regions - so we need at least speed of sound and density for the material properties for acoustic regions.
Viewing 15 reply threads
  • The topic ‘problem adding acoustic absorption surface’ is closed to new replies.
