August 23, 2022 at 5:37 am
Laure
SubscriberHello Fluids community,
I just started using Fluent and I am trying to find a way to import observed ambient temperature as wall boundary condition (convection). I have a tank model and I want to import measured air temperatures to model heat transfer to a tank that contains water and sand. I modelled this case with Mechanical, but I want to see the effect of water movement (due to temperature changes) on sand thermal propagation.
I couldn’t find a tabular data option (as in the case of Mechanical) in the thermal tap of the fluent boundary condition definition.I will appreciate your help. Thanks in advance.
August 23, 2022 at 6:07 am
DrAmine
Ansys EmployeePlease have a look into Fluent User's Guide Chapter Profiles to learn about deploying spatial profiles. CSV file with your data is the way to go. One the profile has been read into Ansys Fluent you can then hook it in the "Free Stream Temperature" field.
August 25, 2022 at 6:11 am
August 24, 2022 at 6:36 am
August 24, 2022 at 7:26 am
August 24, 2022 at 2:29 pm
Forum ModeratorIn the Excel screen grab I think you skipped the "delimited" step in the file import.Â
August 25, 2022 at 5:51 am
Laure
SubscriberNow, it worked. Thanks a lot.
August 25, 2022 at 6:31 am
DrAmine
Ansys EmployeeWelcome and Happy Modeling!
August 25, 2022 at 10:56 am
August 25, 2022 at 11:52 am
DrAmine
Ansys EmployeeYou hook the temperature from the profile.
- The topic ‘Time dependant boundary conditions (convection) in Fluent’ is closed to new replies.
6495
