Free Vibration of Beams — Lesson 1
This lesson covers the concept of structural vibration in continuous systems. It delves into the study of systems that can be modeled as a mass spring dashboard system, discussing the building blocks of such systems and the degrees of freedom involved. The lesson further explores the equation of motion for continuous systems, using a beam exposed to arbitrary loading as an example. It explains the process of solving the equation of motion using the separation of variables technique and how to derive the natural frequency of the system. The lesson also discusses the impact of different boundary conditions on the free vibration response.
Video Highlights
Explanation of the mass spring dashboard system as a building block for understanding structural vibration - 0:42
Discussion on the differences between discrete and continuous models - 1:22
Explanation of how to model a beam exposed to arbitrary loading - 1:53
Explanation of how to solve the equation of motion using a free body diagram - 3:43
Identification of the forces acting on a differential element of the beam - 4:31
Derivation of the equation of motion for the beam - 5:01
Explanation of how to solve the equation of motion using separation of variables - 12:12
Derivation of the natural frequency of the system - 45:37
Explanation of how to find the total response of the system - 53:35
Key Takeaways:
- Structural vibration in continuous systems can be modeled using a mass spring dashboard system.
- The equation of motion for continuous systems can be developed and solved using the separation of variables technique.
- The natural frequency of the system can be derived from the equation of motion.
- Different boundary conditions can impact the free vibration response of the system.
- The response of a continuous system can be represented in terms of its modal response.
