Response due to Harmonic Excitation (Continued) — Lesson 4
This lesson covers the dynamic response of a system excited by a harmonic force. It delves into the components of a mass spring damper system and the equation of motion. The lesson further explains the transient response and steady state response, and how damping affects these responses. It introduces the concept of dynamic amplification and resonance. The lesson also discusses how to quantify damping using the half power bandwidth technique and logarithmic decrement technique. For instance, if you have a system driven by a harmonic excitation, you can estimate the amount of damping present in the system using these techniques.
Video Highlights
Explanation of the components of the system, including the mass, spring, and damper - 0:38
Discussion on the equation of motion for the system - 1:05
Explanation of the transient response and steady state response of the system - 1:45
Discussion on the concept of dynamic amplification and its calculation - 2:35
Discussion on the concept of damping and its effect on the system response - 3:56
Introduction to the technique of logarithmic decrement for quantifying damping - 5:21
Explanation of the concept of dynamic magnification factor and its calculation - 6:08
Discussion on the concept of bandwidth and its calculation - 9:12
Explanation of the half power bandwidth technique for measuring damping - 23:43
Key Takeaways:
- Forced vibration occurs when an external force is applied to a system, in this case, a mass-spring-damper system.
- The equation of motion for this system is derived and solved, considering different types of forces.
- The response of the system to the excitation is calculated, and the constants involved are estimated.
- The concept of a dynamic magnification factor is introduced, which amplifies the static response in a dynamic system.
- Resonance, a dangerous situation where the driving frequency matches the natural frequency of the system, is discussed.
