Damped Forced Vibration — Lesson 2
This lesson covers the concept of forced vibration cases, focusing on the solution for a homogeneous case. It explains the governing equation of motion and how to solve it for a forcing function. The lesson also discusses the components of the total solution, including the complimentary function and the particular integral. It further elaborates on the nature of the solution when the forcing function is constant. The lesson concludes with an explanation of the steady state response and transient response of a system under forced vibration.
Video Highlights
Explanation of the problem statement and the governing equation of motion - 0:31
Discussion on the homogeneous case and the components of the total solution - 2:03
Discussion on the nature of the solution for a constant forcing function - 3:24
Explanation of the total response due to a constant force and the task of finding the constants C and D - 6:25
Explanation of the nature of the solution when the forcing function is constant - 13:48
Introduction to the case of forced vibration with harmonic excitation - 18:06
Explanation of the proposed solution for harmonic excitation and the task of finding the constants A and B - 21:30
Discussion on the nature of the total solution and the difference between transient and steady state response - 34:42
Key Takeaways:
- Forced vibration cases involve a system with a spring attached to a mass and a damper.
- The governing equation of motion for these cases is m ẍ + c ẋ + k x = F
- The total solution for these cases has two components: the complimentary function and the particular integral.
- When the forcing function is constant, the system will have a permanent deformation, and the particular integral will be equal to the force applied divided by the lateral stiffness of the system.
- The response of a system under forced vibration consists of an initial transient response that gradually dies down due to damping, leading to a steady state response.
