This lesson covers the fundamental principles of structural dynamics, focusing on Newton's laws and D'Alembert's principle. It explains how these principles can be used to develop the equation of motion for a structure. The lesson starts with a detailed explanation of Newton's three laws of motion, emphasizing the second law, which states that the rate of change of momentum is equal to the net force applied. The lesson then introduces D'Alembert's principle, which extends Newton's second law to include the concept of dynamic equilibrium. The lesson also discusses the concept of degrees of freedom, which is the number of independent coordinates required to define the deformed shape of a body. The lesson uses illustrative examples such as a pendulum and a portal frame to explain these concepts.
Introduction to the course on Structural Dynamics and the first lecture's focus on Newton's law and D'Albert's principle - 0:24
Discussion on the concept of momentum and its relation to force and acceleration - 2:53
Explanation of how Newton's second law can be applied to solve problems involving force and acceleration - 3:39
Introduction to D'Albert's principle, which extends Newton's second law to define dynamic equilibrium - 27:30
Definition of degrees of freedom, which is the number of independent coordinate systems required to define the deformed shape of a body - 38:24
Application of D'Albert's principle to derive the equation of motion for a single-story single-bay portal frame - 48:38
- Newton's laws of motion are fundamental to understanding structural dynamics.
- D'Alembert's principle extends Newton's second law to include the concept of dynamic equilibrium.
- The concept of degrees of freedom is crucial in defining the deformed shape of a body.
- The equation of motion for a structure can be developed using these principles.
- The lesson uses practical examples to illustrate these concepts, making them easier to understand.
