This lesson covers the concept of forced vibration in multiple degrees of freedom (MDOF) systems. It delves into the derivation of the equation of motion, the transformation of generalized coordinates into modal coordinates, and the decoupling of the system equation. The lesson also explains how to solve the equation of motion using the Damel integral and how to find the response in the original coordinate system. It further discusses the impact of resonance on the structural response and how to avoid it. An example of a three-degree-of-freedom system is used to illustrate these concepts.
Discussion on the concept of coupled equations - 1:23
Explanation of the decoupled system equation - 1:43
Discussion on the initial conditions of the system - 2:47
Explanation of the transformation process in the matrix equation - 2:35
Explanation of the decoupled mass and damping matrices - 3:08
Discussion on the tuning of the F Matrix - 3:33
Explanation of the equations in terms of modal coordinates - 4:26
Explanation of the response due to unit impulse - 10:18
Discussion on the response in the original coordinate system - 12:11
Discussion on the concept of resonance - 41:28
Conclusion of the discussion on the response of MDOF system in time domain - 43:34
- The equation of motion for forced vibration in MDOF systems can be derived and transformed into modal coordinates for easier analysis.
- The system equation can be decoupled using a transformation matrix, which simplifies the process of finding the solution.
- The Damel integral can be used to solve the equation of motion and find the response in the original coordinate system.
- Resonance can significantly increase the structural response in MDOF systems. It can be avoided by adjusting the driving frequency.
- The response of MDOF systems can be analyzed in both the time and frequency domains.
