Employing Damping for RBD Analysis — Lesson 9
Do you have an example for employing alpha and beta damping for CMS bodies in rigid body dynamics via command snippets?
Explore the solution file to learn how to define and take damping behavior for CMS bodies into consideration during a rigid body dynamics analysis.
Note: It is important to set the command snippets under the condensed parts to be sent to the RBD solver instead of the APDL solver.
You can access the relevant file here: Download File
