Appending Discrete Phase Model Summary into One File when Using Transient Particle Tracking
How to append Discrete Phase Model Summary into one file when using transient particle tracking?
A possible solution is to let Ansys Fluent append the dpm summary output into a single file via Scheme and system commands. This procedure can be enhanced and extended by the user. Here a journal file which could be executed as the Ansys Fluent Calculation Activity at user defined frequency is required.
Please refer to the attached document below for more information.
