Importing Gas-Liquid Interface from Ansys Fluent VOF Simulation to a Pre-processor – Lesson 1
Is there a way to import the gas-liquid interface obtained from Fluent VOF simulation to a pre-processor as a surface?
It is possible to export the volume of fluid (VOF) iso-surface as an STL from either Ansys CFD Post or Fluent software directly and this STL file can be imported into pre-processor e.g. Ansys Discovery. Once the STL file is loaded into Discovery software, reverse engineering tools can be used to manipulate the STL to create a surface.
