Using Frequency-Dependent Materials — Lesson 1
Is it possible to use frequency-dependent materials in harmonic response analysis?
Yes, you may use frequency-dependent materials for performing harmonic response analysis using Mechanical software. Please refer to the attachments to access the solution.
You can access the files here: Download Files
For additional details, refer to the document here:
