Modifying DPM Injection Mass Flow using UDF
How to modify DPM injection mass flow using UDF?
If you want to modify injection inputs using UDF, you will require the following DPM macro
DEFINE_DPM_INJECTION_INIT
This macro provides access to particle variables like number of particles in a parcel "p->number_in_parcel", DPM mass flow rate "P_FLOW_RATE(p)" etc. These variables are linked as follows:
Stream mass flow rate = (Number of particles in a parcel) *(Mass of single particle) / ( Injection time interval)
If you want to modify the mass flow rate, you should modify it using P_FLOW_RATE(p) and not by modifying p->number_in_parcel. This is because p->number_in_parcel is derived from P_FLOW_RATE(p).
In general, p->number_in_parcel should never be modified in the UDF. Mass flow rate should be modified by changing P_FLOW_RATE(p) only.
