This lesson covers the calculations involved in heat load and the active thermal management system. It further discusses passive thermal management, heat sinks, heat pipes, thermal interface materials, and phase change materials. The lesson also touches on the importance of thermal insulation and the parameters monitored in a battery pack. It also covers the different types of tempearature sensors for battery pack.
00:18 - Introduction
01:35 - Passive thermal management and heat sink
04:36 - Discussion on thermal interface materials
06:10 - Phase change materials and their role in thermal management
09:26 - Example on PCM mass calculation
14:58 - Thermal management materials and design
19:41 - Materials for battery pack components
20:40 - Explanation of thermal insulation
23:46 - Monitoring thermals of a battery pack
25:39 - Different types of temperature sensors used in battery packs
- Thermal management systems are crucial for maintaining the optimum temperature for a cell to maximize its cycle life.
- Different methods of thermal management include active and passive systems.
- Heat sinks and heat pipes are widely used in passive thermal management systems.
- Thermal interface materials are used to reduce thermal contact resistance.
- Phase change materials absorb heat during phase changes, providing effective thermal management.
- Thermal insulation is important to prevent the spread of thermal runaway from one cell to another.
- In a battery pack, temperature is the primary parameter monitored for thermal management.
