The results of each gauge can be approximated using beam theory as shown in this document.
Note that the document uses a different bike crank and a different gauge location so while the process is the same, you will obtain different results. Also, know that the hand calculation uses tensor shear strain while the Ansys analysis reports engineering shear strain (which is two times the tensor shear strain).
It is always a good idea to make some rough hand-calculations to validate the simulation result. So before even starting our simulation, let's try to get a rough idea of what our answers will be. Here, we provide you with the main steps to follow and give you the final answer for the left gauge for you to verify that you did the work properly.
Main steps:
*Caution: Know the definition of "engineering" shear strain,
and be careful with the sign of your angle when doing the transformation.
And finally, think about whether shear stress or shear strain can be neglected and when that is the case.
This course assumes that you have already conducted a stress analysis of the bike crank. The final Ansys Workbench project (.wbpz) file is going to be our starting point in this course. We will reuse the same bike crank geometry and add the strain gauge elements.
Click here to download the Ansys Workbench project file.
Restore the archived file in Ansys Workbench. The following video will show you how to make a copy of your previous analysis system within the project page.
Summary of steps in the above video:
