The boundary conditions (the fixed support at the left hole and the 1lbf upward load at the right hole) should already be defined in the bike crank project file. The boundary conditions are:
In this lesson, we give each gauge a local coordinate system, or elemental triads. These will be later used to compute the strain solution in the proper direction. We then update the solution.
Summary of steps in the above video:
