Operation of Synchronous Machines — Lesson 8
This lesson covers the operation of synchronous machines, which are large capacity machines that can handle up to 100 megawatts of power. The lesson explains the difference between synchronous machines and induction motors, highlighting the independence of the excitation current in synchronous machines from the AC voltage. It also discusses the conditions necessary for the operation of a synchronous machine, such as the need for the rotor to run at synchronous speed. The lesson further delves into the process of synchronizing a synchronous machine with a bus, explaining the role of lamps in indicating the correct instance for synchronization. For instance, when all lamps are dark, it indicates the correct instance for synchronizing the machine terminals with the bus terminals.
Video Highlights
00:15 - Introduction to synchronous machines and their capacity
02:19 - Discussion on the conditions necessary for the operation of a synchronous machine
10:35 - Explanation of the process of synchronizing a synchronous machine with a bus
18:10 - Demonstration of the role of lamps in synchronization
Key Takeaways
- Synchronous machines are large capacity machines that can handle up to 100 megawatts of power.
- Unlike induction motors, the excitation current in synchronous machines is independent of the AC voltage.
- For a synchronous machine to operate, the rotor must run at synchronous speed.
- Synchronizing a synchronous machine with a bus involves monitoring the brightness of lamps connected between the machine and the bus. When all lamps are dark, it indicates the correct instance for synchronization.
