Satellite Navigation Systems - Part II — Lesson 2
This lesson covers the fundamentals of satellite navigation systems, focusing on how to estimate position, velocity, and time. It delves into the concept of position estimation, explaining how it is derived from a quadratic equation and can be refined through a technique of linearization. The lesson also discusses time estimation, which requires a defined reference time and the elapsed time from the reference instant. The lesson further explores velocity estimation, which is simplified through the pseudo range rate derived from the Doppler shift. The lesson also highlights the importance of error correction in satellite navigation systems and introduces different global navigation satellite systems like GPS, GLONASS, Galileo, and IRNSS.
Video Highlights
00:18 - Position, time, velocity and estimations
03:25 - Basic assumptions of Position, Velocity, Time (PVT) estimation
03:55 - Global Navigation Satellite System (GNSS) signal and ranging code
06:28 - Format of the navigation message transmitted from the satellite
09:18 - Signal quality required for demodulation
12:04 - Sources of error in satellite navigation
17:30 - Differential GPS (DGPS) technique for error correction
19:49 - Global Navigation Satellite System (GNSS)
20:23 - GPS constellations
21:22 - Other Sat-NAV Systems
Key Takeaways
- Position estimation in satellite navigation is derived from a quadratic equation and can be refined through linearization.
- Time estimation requires a defined reference time and the elapsed time from the reference instant.
- Velocity estimation is simplified through the pseudo range rate derived from the Doppler shift.
- Error correction is crucial in satellite navigation systems to ensure accurate position, velocity, and time estimations.
- There are different global navigation satellite systems, including GPS, GLONASS, Galileo, and IRNSS, each with unique features and specifications.
