This lesson covers the various types of antennas used in the ground segment and the ITU regulation of a ground segment. It further explains the concept of a 'parking slot' in satellite communication and the importance of antenna patterns. The lesson also touches upon the different types of antenna mounts like the Parabolic Reflector, Offset fed Mount, Cassegrain Mount, and Beam Wave Guide Antenna. Lastly, it introduces the concept of Very Small Aperture Terminal (VSAT) and explains why a VSAT always needs a large station at the other end.
00:18 - Introduction
01:47 - Ground station antenna pattern as per ITU Regulation
05:45 - Different types of antenna mounts
07:33 - Prime focus mount
10:48 - Offset fed Mount
13:00 - Cassegrain Mount
15:41 - Beam Wave Guide Antenna
17:43 - Very Small Aperture Terminal (VSAT)
20:06 - Power amplifier ratings requirements for a VSAT
24:37 - Receive antenna gain and Transmit antenna gain
- Ground segments in satellite communication are categorized based on their communication methods and the services they provide.
- The ITU Regulation of a ground segment ensures more satellites can be used without interference.
- Different types of antenna mounts are used based on their efficiency and the specific requirements of the communication system.
- Very Small Aperture Terminal (VSAT) is a small antenna used in satellite communication that always requires a large station at the other end for communication.
- Practical understanding of how to calculate the Transmit Power from a VSAT Transmit Power Amplifier output.
